on 01-29-2024 04:54 PM - edited 15 hours ago by ZenBot
[Graphic Card] Condition of Fan Start and Fan Stop on RTX30 & RTX40 series
RTX 3090 RTX 3080 RTX 3070 Fan Start GPU Temperature is higher than 55 degree
or Wattage is higher than 100WGPU Temperature is higher than 55 degree
or Wattage is higher than 100WFan Stop GPU Temperature is lower than 50 degree AND
-Wattage is lower than 50 watt AND
-0dB Fan mode is switched "on" in GPU Tweak IIGPU Temperature is lower than 50 degree AND
-Wattage is lower than 40 watt AND
RTX 3060 Ti | RTX 4090/4080/4070TI/4070 | |
Fan Start | GPU Temperature is higher than 52 degree or Wattage is higher than 100W | GPU Temperature is higher than 55 degree or Wattage is higher than 100W |
Fan Stop | GPU Temperature is lower than 48 degree AND -Wattage is lower than 40 watt AND -0dB Fan mode is switched "on" in GPU Tweak II | GPU Temperature is lower than 50 degree AND -Wattage is lower than 50 watt AND -0dB Fan mode is switched "on" in GPU Tweak II |
Note: Actual Wattage and Temperature may vary depending on product configuration, usage, operational conditions and power management settings.
