on
01-29-2024
05:23 PM
- edited on
10-07-2025
05:15 AM
by
ZenBot
[GlideX] How to Use Screen Mirror PC Control
The “PC Control” function of the Screen Mirror allows users to use the computer mouse to control the mobile device on the computer, use the keyboard for input, and also output the sound of the mobile device from the speaker on the computer. If you encounter the difficulties, please seek troubleshooting based on the type of device you are using.
Troubleshooting for iOS device users
Troubleshooting for Android device users
1. Function connection failed
If you enter the [PC Control
] function page, it shows that the function connection failed
, please click the [Retry] button of the mirror window function. If the connection is still not successful, please try to pair the devices' Bluetooth again.
2. Use the mouse to control the mobile device on the computer
2.1 Enable [AssistiveTouch] - To display the cursor on the mirrored window, please go to your mobile device [Settings] > [Accessibility] > [Touch] > Turn on [AssistiveTouch], or ask Siri to [Turn on AssistiveTouch].
2.2 Adjust the speed of the Trackpad & Mouse - To have the better user experience, go to your mobile device [Settings] > [General] > [Trackpad & Mouse], we recommend that you drag the "Tracking Speed" slider to the lowest. At the same time, turn off the [Natural Scrolling] setting to maintain your scrolling behavior on the computer.
2.3 Confirm to unlock the [screen orientation] - To avoid the mouse operated unexpectedly, please make sure that the “screen orientation” is unlocked. You can swipe down from the upper right corner of the screen to open "Control Center" and tap the [screen orientation] button to confirm that the function is unlocked.
3. Use the keyboard to input
The computer keyboard is the Bluetooth keyboard of your mobile device. If you want to use the hotkey to switch languages, you can press [Ctrl + Space] keys to switch. If you want to quickly return to the homepage of your mobile device, you can press the [Ctrl + H] keys, or click the home button on the side menu of the mirrored window.
, please enter the mobile device [Bluetooth] settings, select the current [paired device] name, enter the device's [Settings], and turn on the corresponding [Audio] or [Input Device] permission, and then click the [Retry] button on the [PC Control
] function page of the mirrored window. If the connection is still not successful, please try to pair the devices’ Bluetooth again.
To adjust the pointer speed, you can click the [PC Control] button from the side menu of the mirrored window and click the [Pointer Speed] [Settings] button on the [Keyboard & Mouse
] tab to enter the mobile device [Mouse and trackpad speed] system page, you can customize the speed according to your personal preference.
The computer keyboard is the Bluetooth keyboard of your mobile device. If you want to use the hotkey to switch languages, you can press [Shift + Space] key to switch, for example, switch from English to Chinese; if you want to switch the input method, press [Shift + Alt] to switch, for example, switch from Samsung keyboard to Google keyboard.
