FAQBot
Community Manager
Community Manager
[Glasses]What safety precautions and maintenance methods should be followed when using glasses?
1.) Here are some safety precautions to follow when using the glasses:
① Do not connect the glasses directly to a power adapter.
② Avoid exposing the optical components directly to sunlight.
③ Do not use the glasses in rainy or humid environments.
④ It is best to take a few minutes of rest after prolonged use. Individual situations may vary, so if you feel uncomfortable, consider taking more frequent and longer breaks.
2.) Methods for maintaining the glasses:
① Regular Cleaning:
     Use a specialized glasses cleaner and a soft microfiber cloth to clean the lenses. Avoid wiping with clothing or tissues, as these materials may scratch the lenses.
② Avoid High Temperatures and Direct Sunlight:
     Do not leave the glasses in a car or other high-temperature places, as this may damage the lens coating.
③ Proper Storage:
     Store the glasses in a glasses case to avoid dropping or scratching them. When not wearing the glasses, it is best to put them back in the case.
④ Avoid Contact with Chemicals:
     Keep the glasses away from perfumes, cleaners, and other chemicals, as these may damage the lens coating.
Version history
Last update:
Sunday
Updated by:
Contributors
