FAQBot
Community Manager
Community Manager
[Gaming Chassis] ROG Strix Helios GX601 Case Glass Side Panel Replacement
Disassemble the side panel
   Note: Please put the case on a flat table to prevent the side panel from falling during disassembly and assembly.
             Please handle with care when disassembling and assembling the glass side panel to avoid collision/drop/heavy pressure.
Press the button on the back of the chassis and the panel will be release, lift up the panel to remove.
Assemble the side panel
Hold the panel and put lower edge of panel into the panel groove at the bottom of case, then push panel upper edge into the latch on top of case until hearing "click" to close panel.
Version history
Last update:
Sunday
Updated by:
Contributors
