- Article History
- Subscribe to RSS Feed
- Mark as New
- Mark as Read
- Bookmark
- Subscribe
- Printer Friendly Page
on
05-18-2024
10:05 AM
- edited
3 weeks ago
by
ZenBot
[ExpertWiFi] How to set up ExpertWiFi devices as AiMesh node mode?
If you want to add your ExpertWiFi devices to an AiMesh ecosystem, please follow the steps below for configuration.
Configurations
First, go to Google Play or iOS App Store and search for ASUS ExpertWiFi, or use your phone to scan the QR code to download the App.
Note: Take ExpertWiFi EBG19P as AiMesh router and ExpertWiFi EBA63 as an access point as an example for the following setup process.
1. Launch the ASUS ExpertWiFi app and follow the instruction to set up ExpertWiFi EBG19P.
Note: Please refer to [ExpertWiFi]How to set up the ExpertWiFi Wired Router via the ExpertWiFi app (iOS/Andriod)? to learn more information.
2. After setup, the ExpertWiFi app will pop up a notice asking you to allow ExpertWiFi EBA63 to set up as an AiMesh node.
Note: If no pop-up notice appears, you can also click [+] > [Add AiMesh node] to search for AiMesh devices.
3. After allowing it, ExpertWiFi EBA63 will seamlessly integrate into the AiMesh ecosystem of ExpertWiFi EBG19P as an AiMesh node.
FAQ
1. What should I do if I'm unable to successfully set up the ExpertWiFi AiMesh node mode?
First, reset the ExpertWiFi device (node) to its factory default settings, and then try the setup process in this article again.
For how to reset to factory default settings, please refer to this FAQ: [ExpertWiFi] How to restore your ExpertWiFi router to factory settings?
2. If my AiMesh router is an ExpertWiFi router, can I use Asus Router App to set it up?
As mentioned in this article:
If your AiMesh router is an ExpertWiFi router, please use the Asus ExpertWiFi App for the setup.
If your AiMesh router is an Asus router, please use the Asus Router App for the setup.
3. Can an Asus router join an ExpertWiFi AiMesh router as an AiMesh node?
Yes. Please follow the steps in this article to complete the setup.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer to this link.
