on 01-29-2024 07:16 PM - edited Sunday by ZenBot
[Desktop Chassis] TUF Gaming GT501 top cover disassembly and assembly instructions
Notice
1. Please, wear gloves to protect your hands before disassembling and assembling, and pay attention to the corners of the parts to avoid scratches.
2. When the side panel is made of glass, please handle it with care when disassembling the side panel of the case to avoid collision/fall/stress.
3. When disassembling, please lay the casing flat on a flat surface to prevent the side panel from falling during disassembly and assembly.
4. Please, tidy up the relevant wires during assembly to avoid damaging the wires during the assembly process.
Preparation
Phillips screwdriver PH2
Step 1. Unscrew the 4 screws on left and right panels.
Step 2. Lift the left and right panels.
Step 3. Hold the groove under the front panel, and pull hard forward and up to remove it.
Step 4. Remove the screws in corresponding positions under the back strap of the top cover.
Step 5. Remove a total of 12 screws, 3 screws a set, close to the four corners of the top cover (It is easier to remove the screws by inverting the chassis).
Step 6. After removing the screws, hold the red area and pull the top cover upward to open it.
Step 7. Removal of top cover completed.
Visit ASUS official website to learn more about TUF Gaming GT501 https://www.asus.com/motherboards-components/gaming-cases/tuf-gaming/tuf-gaming-gt501/
