FAQBot
Community Manager
Community Manager
[Desktop Chassis] ROG Z11 front panel disassembly and assembly instructions
Notice
1. Please, wear gloves to protect your hands before disassembling and assembling, and pay attention to the corners of the parts to avoid scratches.
2. When the side panel is made of glass, please handle it with care when disassembling the side panel of the case to avoid collision/fall/stress.
3. When disassembling, please lay the casing flat on a flat surface to prevent the side panel from falling during disassembly and assembly.
4. Please, tidy up the relevant wires during assembly to avoid damaging the wires during the assembly process.
Preparation
Phillips screwdriver PH2
Step1. Press the clip at the latch on the top cover and lift to remove.
Step2. Unscrew the 4 screws in the red circles.
Step3. Lift the left and right panels.
Step4. Press the clip at the latch on the bottom cover and lift to remove.
Step5. Unscrew the two screws on top of the front panel.
Step6. Unscrew the hidden safety screw.
Step7. Lift the front panel.
Note: (1) The plastic buckle may be a bit tight, requiring some force.
           (2) Light cables are connected to the front panel, so be cautious not to lift it too high.
Step8. Removal of front panel completed.
Visit ASUS official website to learn more about ROG Z11 https://rog.asus.com/cases/rog-z11-model/
Version history
Last update:
Sunday
Updated by:
Contributors
