on 01-29-2024 06:16 PM - edited Sunday by ZenBot
[Desktop Chassis] ROG Strix Helios FAN HUB disassembly and assembly precautions
Notice
1. Please, wear gloves to protect your hands before disassembling and assembling, and pay attention to the corners of the parts to avoid scratches.
2. When the side panel is made of glass, please handle it with care when disassembling the side panel of the case to avoid collision/fall/stress.
3. When disassembling, please lay the casing flat on a flat surface to prevent the side panel from falling during disassembly and assembly.
4. Please, tidy up the relevant wires during assembly to avoid damaging the wires during the assembly process.
Tools required
1. Remove the left/right glass side panels
2. Unlock two screws and open the cable cover.
3. Remove the fan and FIO cables and the SATA power supply plugged into the motherboard.
4. Remove the 3 screws to replace the FAN HUB.
