on
01-29-2024
06:16 PM
- edited
Saturday
by
ZenBot
[Desktop Chassis] ProArt PA602 cable management disassembly and assembly instructions
Notice
1. Please wear gloves to protect your hands before disassembling and assembling, and pay attention to the corners of the parts to avoid scratches.
2. When the side panel is made of glass, please handle it with care when disassembling the side panel of the case to avoid collision/fall/stress.
3. When disassembling, please lay the casing flat on a flat surface to prevent the side panel from falling during disassembly and assembly.
Preparation
Phillips screwdriver PH2
Step1. Open the both side panel and remove them.
Step2. Replace the cable management.
A. Cable cover
(1) Unscrew the two screws on the upper and lower sides.
(2) Removal of cable cover completed.
B. Cable box
(1) Unscrew the two screws next to the cable cover.
(2) Open the cable box on the right side of PA602 and remove the cables inside.
(3) Removal of cable box completed.
C. Velcro straps & mounts
(1) Squeeze inward with two fingers to remove mounts from the latches.
(2) Removal of Velcro straps & mounts completed.
Visit ASUS official website to learn more about ProArt PA602 https://www.asus.com/motherboards-components/gaming-cases/proart/proart-pa602/
