FAQBot
Community Manager
Community Manager
[Desktop Chassis] A31/A31 PLUS Panel Cover and FIO Disassembly and Assembly Instructions
Notice
1. Kindly wear gloves to protect your hands before proceeding with disassembly or assembly. Pay special attention to the corners of the parts to avoid any scratches.
2. When the side panel is made of glass, please handle it with extreme care during disassembly to avoid any collisions, falls, or undue stress.
3. When disassembling, please lay the casing flat on a stable surface to prevent the side panel from falling during the process.
4. Kindly ensure that the relevant wires are neatly arranged during assembly to prevent any damage to the wires throughout the process.
5. Keep track of all screws and small components during disassembly and assembly to avoid losing any parts.
Preparation
  • Phillips screwdriver PH2
  • Remove both side panels and the front panel.
[Desktop Chassis] A31/A31 PLUS Side Panel Disassembly and Assembly Instructions
[Desktop Chassis] A31/A31 PLUS Front Panel Disassembly and Assembly Instructions
Dissembling method:
Side Panel cover:
Release the two screws at the rear of the case then slide Side Panel Cover to remove.
Front panel cover:
Release the three screws at the upper side of the Front Panel Cover to remove.
FIO Dissembling method:
Loosen the six screws on both the upper and lower sides of the FIO module, pull out to remove.
Note: Please release the ties to FIO cables before disassembly.
For more information, please visit product spec page and support site.
Version history
Last update:
10 hours ago
Updated by:
Contributors
