yesterday - edited 10 hours ago by ZenBot
[Desktop Chassis] A31/ A31 PLUS Fan Disassembly and Assembly Instructions
Notice
1. Kindly wear gloves to protect your hands before proceeding with disassembly or assembly. Pay special attention to the corners of the parts to avoid any scratches.
2. When the side panel is made of glass, please handle it with extreme care during disassembly to avoid any collisions, falls, or undue stress.
3. When disassembling, please lay the casing flat on a stable surface to prevent the side panel from falling during the process.
4. Kindly ensure that the relevant wires are neatly arranged during assembly to prevent any damage to the wires throughout the process.
5. Keep track of all screws and small components during disassembly and assembly to avoid losing any parts.
Fan Compatibility: Maximum fan amount :120mm *10 or 140mm *3
( For information about pre-installing fans, please refer to specification page of product )
Preparation
[Desktop Chassis] A31/A31 PLUS Side Panel Disassembly and Assembly Instructions
[Desktop Chassis] A31/A31 PLUS Front Panel Disassembly and Assembly Instructions
Dissembling method:
Loosen the four screws at the back of fan bracket to detach it.
Presinstalled Fan of A31 PLUS :
Note: Please check the orientation of the PWM and ARGB connectors when attaching them.
For more information, please visit product spec page or support site.
