on
08-02-2025
10:55 AM
- edited on
10-07-2025
03:40 AM
by
ZenBot
[Computer Chassis] A32 / A32 PLUS Disassembly and Assembly Instructions
Notice
1. Kindly wear gloves to protect your hands before proceeding with disassembly or assembly. Pay special attention to the corners of the parts to avoid any scratches.
2. When the side panel or front panel is made of glass, please handle it with extreme care during disassembly to avoid any collisions, falls, or undue stress.
3. When disassembling, please lay the casing flat on a stable surface to prevent the side panel from falling during the process.
4. Kindly ensure that the relevant wires are neatly arranged during assembly to prevent any damage to the wires throughout the process.
5. Keep track of all screws and small components during disassembly and assembly to avoid losing any parts.
Preparation
Phillips screwdriver PH2
Panels
Top panel
Loosen the hand screws by turning them counterclockwise, then slide the panel towards the rear then lift to remove.
Side Panels
Grasp the sides of the door panel and gently pull the top edge outward to detach it from the clips. Then, lift the panel off.
Front Panel
Remove the left side door. Then, unscrew the two front panel securing screws and slide the front panel out.
Front I/O Module
*Preparation: Before replacement, ensure all cable ties are removed and all connectors are disconnected from their headers.
Remove the right panel. Then, unscrew the three securing screws and carefully pull the module (along with its cable) out.
Fan (A32 PLUS only)
Side : Remove the right panel. Unscrew the four screws from the fan. Then, carefully remove the fan, along with its cables.
Rear: Remove the Left panel. Unscrew the four screws from the fan. Then, carefully remove the fan, along with its cables.
Feet
Unscrew the foot securing screw located in the round hole to replace the foot.
How to get the (Utility / Firmware)?
You can download the latest drivers, software, firmware and user manuals in the ASUS Download Center.
If you need more information about the ASUS Download Center, please refer this link.
