on
01-29-2024
05:52 PM
- edited on
10-07-2025
05:32 AM
by
ZenBot
[Chromebook] Troubleshooting - Wireless Network Problems on Chromebook
We first have to check whether the problems are caused either by the computer or by Internet equipment (modem/Internet cable/wireless router) or the Internet service provider before we look to solve the Internet problem.
This troubleshooting only offers solutions to Internet dysfunction caused by a computer. (The common symptoms, such as Wi-Fi fails, no Wi-Fi signal, etc.)
For other inquiries about Internet equipment/service, please contact the Internet service provider for further information.
Assume that you use both Computer (A) & Smart Phone (B), and connect them to the Internet network by Wi-Fi:
Both (A) & (B) cannot connect to the internet -> problems usually are caused by Internet facilities or Internet service providers.
(A) cannot connect to internet but (B) is able to -> Please refer to the solutions below:
Make sure the wireless function is activated
Click [Status Bar]① at the bottom-right of the screen, then ensure Wi-Fi is [Turn on]②.
Note: When the Wi-Fi icon is displayed as blue
, it means the function is enabled.
Check that the network you want to connect to works with your Chromebook
Please make sure the Wi-Fi networks that work with Chromebook:
The above information is from Google’s official website, you also can refer to Chromebook Help for more details.
Enable or disable a wireless network or Wi-Fi
, it means the function is disabled.
④.
behind the Wi-Fi network⑦.
Use “Diagnostics” to troubleshoot the connectivity issues
Read the following article to learn how to check connectivity issues via Google “Diagnostics” app: Diagnostics feature on Chrome OS.
Other troubleshooting
If the Wi-Fi problems persist after completing all troubleshooting steps listed above, please try the steps below:
until the device power off, then power it on again.
For more details, please refer to Chromebook Help from Google:
https://support.google.com/chromebook/answer/6318213
If your problem is not worked out with above solution and information, please contact ASUS customer service center for further information.
