on
01-29-2024
05:54 PM
- edited on
10-07-2025
05:36 AM
by
ZenBot
[Chromebook] Troubleshooting - How to fix backlit keyboard problems
Before troubleshooting, read the following article to learn more about enabling backlit keyboard: How to enable Backlit keyboard.
If the backlit keyboard cannot be enabled or the brightness is abnormal after you read the above article, please follow the steps below.
If the backlit keyboard does not work, please check you are not at the maximum or minimum for that setting.
Note: The shortcuts may be different based on different models, you can learn more about finding the right user manual to check the shortcuts in this article: How to search and download user manuals.
| The maximum of keyboard backlight brightness | |
| The minimum of keyboard backlight brightness |
When the brightness sets to minimum, the backlit keyboard will turn off. |
If the shortcuts of backlit keyboard do not work, you may have enabled the hotkeys as function keys (such as F1, F2, etc.). Please refer to the following steps to disable the feature.
| Make keyboard brighter | Alt + |
| Dim keyboard | Alt + |
Other backlit keyboard problems
If you have other problems with your backlit keyboard, try these steps:
For more details, please refer to Chromebook Help from Google:
https://support.google.com/chromebook/answer/1047364
If your problem persists after following the instructions above, please contact the ASUS customer service center for further information.
