[ASUS VivoWatch SP (HC-A05)] Suggested Bluetooth connection method in the app if there are two(or more) watches
(1) The order of the watch devices from top to bottom on the app represents the strength of the signal between the watch and the phone.
(2) If you want to connect to the watch on your wrist, it is recommended to directly select the top device to pair with.
