FAQ
Knowledge Base Articles
ASUS Router Plug-n-Share Disks Compatibility List
ASUS Router Plug-n-Share Disks Compatibility List* OS encrypted hard drives are not supported.   Wireless RouterModelFirmware versionMaximumPartitionNumberDisk Format & Maximum Partition Size:File Size:FAT32EXT2EXT3EXT4NTFS   (Read Only)NTFS   (Write...
FAQBot by Community Manager
  • 8 Views
  • 0 comments
  • 0 kudos
[Gaming NB/DT] Armoury Crate Application Introduction
[Gaming NB/DT] Armoury Crate Application Introduction Armoury Crate Introduction (Ver5.0)Armoury Crate Introduction (Ver4.0)Armoury Crate Mobile Version Introduction (Android/ iOS)Armoury Crate - Installation SOPAniMe Matrix™ Display - IntroductionKe...
  • 11 Views
  • 0 comments
  • 0 kudos
MyASUS Frequently Asked Question (FAQ)
MyASUS Frequently Asked Question (FAQ)Table of Contents [Phone] MyASUS App - Introduction  [Motherboard] MyASUS introduction  [Notebook] MyASUS-Unable to reset GPU mode to default value  [Notebook] MyASUS - Introduction  [Notebook] MyASUS- Settings  ...
  • 19 Views
  • 0 comments
  • 0 kudos
[Motherboard] Armoury Crate (Ver 6.0) Introduction
[Motherboard] Armoury Crate (Ver 6.0) IntroductionTable of Contents1. Armoury Crate Introduction 2. Model Supported  3. Armoury Crate Install& Uninstall  4. Launch Armoury Crate  5. Dashboard  6. Devices  7. Playground    7.1 Aura Wallpaper  7.2 Aura...
  • 24 Views
  • 0 comments
  • 0 kudos
[Motherboard]How to turn off some CPU cores under BIOS
[Motherboard]How to turn off some CPU cores under BIOSCatalog:  I: How to turn off some CPU cores (i.e. CCD) on AMD series motherboards?  II:How to turn off some CPU cores (i.e. E-core) on Intel series motherboards? I: How to turn off some CPU cores ...
  • 12 Views
  • 0 comments
  • 0 kudos
[Motherboard] ThunderboltEX 4 Expansion Card Introduction
[Motherboard] ThunderboltEX 4 Expansion Card IntroductionASUS ThunderboltEX 4 is a Thunderbolt™ 4 add-on card that provides 40 Gbps bi-directional bandwidth USB4™ device compatibility with DisplayPort™ 1.4 support.It supports up to five daisy-chained...
  • 11 Views
  • 0 comments
  • 0 kudos
[Chromebook] Why Storage Space is Reduced When Logging in as a Guest
[Chromebook] Why Storage Space is Reduced When Logging in as a GuestIf you log into your Chromebook as a guest, the storage space differs from when logging in with a Google account. Please refer to the following explanation. (The image on the left sh...
  • 30 Views
  • 0 comments
  • 0 kudos
[Motherboard] Dolby Atmos Introduction
[Motherboard] Dolby Atmos Introduction●About Dolby Atmos Dolby Atmos enables sound designers to specify different qualities of each sound, including location, movement, size, focus, and more. This frees game and movie sounds from individual speaker c...
  • 45 Views
  • 0 comments
  • 0 kudos
[Computer Chassis] Assembly Instructions for Graphics Card
[Computer Chassis] Assembly Instructions for Graphics CardWhen installing a graphics card in the case, you may encounter some issues. Here are some tips and solutions to consider before and during installation.Pre-Assembly Guidelines :1. Check the si...
  • 54 Views
  • 0 comments
  • 0 kudos
[Motherboard]How to tell if AMD CPU supports overclocking
[Motherboard]How to tell if AMD CPU supports overclockingWhen you need to set up AMD CPU overclocking in BIOS, you must pay attention to whether the installed AMD CPU supports overclocking.Only when an AMD CPU that supports overclocking is installed ...
  • 59 Views
  • 0 comments
  • 0 kudos
ASUS Fragrance mouse MD101 FAQ
ASUS Fragrance mouse MD101 FAQASUS Fragrance Mouse MD101 is a compact, versatile mouse that features an ergonomic, low-noise design, it is the first ASUS mouse that boasts an internal fragrance compartment with a refillable vial for aromatic oils and...
  • 51 Views
  • 0 comments
  • 0 kudos
[NUC] NUC frequently asked questions
[NUC] NUC frequently asked questions The following lists the common problems of ASUS NUC, you can find the appropriate troubleshooting answers based on the type of problem you encounter.Type of ProblemProblem ItemFAQ LinkNUC Integration InformationRe...
  • 63 Views
  • 0 comments
  • 0 kudos
Top Contributors
