FAQBot
Community Manager
Community Manager
[AIOT]If the DP port on the motherboard/device does not display when using a DP to HDMI cable, how can this be resolved?
Problem Description:
Solution:
Please check the datasheet or manual on the official website to confirm if your motherboard/device supports DP++? If it only shows DP, you need to use a DP to HDMI cable with a built-in active IC converter for it to display correctly.
If the issue persists after trying the above solutions, an engineer will need to inspect the device. Please contact ASUS customer service.
Version history
Last update:
Sunday
Updated by:
Contributors
