Volume slider position misaligned (Zenfone 5z)
ramneek2110
Rising Star I
The volume slider is positioned in such a manner that's it's covered by the notch (notice the black portion, that's the notch part). I don't know if this issue arrived in .46 or when but noticed when playing a YouTube video and found that it persists in home screen and all apps that support landscape rotation. SEE THE SCREENSHOT
7 REPLIES 7
ramneek2110
Rising Star I
@Anders_ASUS @kikoly @CH_ASUS if you could look into this plz...
CH_ASUS
Community Legend II
ramneek2110
Couldnt immediately repro
1) Firmware version?
2) Are you using the default launcher
3) Have you changed any display sizes?
4) If you orient the phone in the other orientation, (notch to the left , power key upwards), is the volume bar also misaligned?
ramneek2110
Rising Star I
1) My firmware version is - WW_00.10.107.46_20200130 (latest one)
2) Yes, using the default Asus launcher
3) No, display size is on default. Tried changing the display size AFTER the issue but didn't solve the problem
4) No, in the other side this issue isn't there. Only on the notch side. Check out the video for more clarity.
CH_ASUS
https://zentalk.asus.com/en/discussion/comment/46449#Comment_46449
ramneek2110
Rising Star I
@CH_ASUS @Anders_ASUS any update?
