Camera Asus Max Pro M1
glenn_lie2508
Why camera on Asus Zenfone Max Pro M1 bad?
Battery Drain Issue,Wifi Not connecting Fast,Heating Issue,Charging Slow,Sound  Is low both on earphones and Without earphones.please Fix this Asus(Bugs Ka Dukaan)Asus Zenfone Max Pro M1
Yachendra
Rising Star II
You can try factory reset the device and check whether Battery drain and Heating issues are solved.
Others, have to wait and see whether Asus gonna fix it or not.
