02-14-2020
02:31 PM
- last edited on
01-16-2024
01:14 AM
by
ZenBot
02-20-2020 09:27 PM
fjaviergji did perform a factory reset after i updated to A10. and its working fine for me. I still insist you visit service centre or PM to any mod here and clarify. ?I have made the factory reset and the problem persists. The LED is red with the phone completely off and charged. I don't remember if the LED was orange before when it had a certain charge like when it is charging while it is on. In summary, the charging LED does not work properly with the phone turned off and if it works correctly with the phone turned on.
I see that I am not the only one affected. Maybe the ones that work for you, if you do a factory reset you also have this problem.
03-09-2020 04:01 AM
fjaviergjIt's a known issue which we're working on solving. No need to visit service centerI have made the factory reset and the problem persists. The LED is red with the phone completely off and charged. I don't remember if the LED was orange before when it had a certain charge like when it is charging while it is on. In summary, the charging LED does not work properly with the phone turned off and if it works correctly with the phone turned on.
03-09-2020 06:53 AM
Anders_ASUSHey can we get these in the next fota:https://zentalk.asus.com/en/discussion/comment/45452#Comment_45452
03-09-2020 07:06 AM
AveranBattery still needs some more optimisations during gaming and normal usagehttps://zentalk.asus.com/en/discussion/comment/47789#Comment_47789
1. Power button customisation options (like 6z and Rog 2)
2. Status bar icon manager
3. .46 update has some random stutters in the UI (I'll appreciate if it gets solved in the next fota 😄 )
Battery optimisation and everything else is perfect
Btw just out of curiosity what's the update schedule from here for 5z, considering it's going to complete it's two years
Is it just security patches for us now ? ( As it's an non priority device now) or we would get to see some "surprises" along the way as porting of new stuff from Zenfone 6 etc (Zen UI 7) *wink*
03-09-2020 07:39 AM
