08-24-2019 09:53 AM
09-03-2019 03:01 AM
09-03-2019 04:48 AM
09-03-2019 11:22 AM
Are you saying that this is normal that the battery life goes from 48 hours to 24 hours just because he installed many apps? That would be really weird.Anders_ASUS said:As you install more and more apps, battery life will go down. This will happen on any phone. If your battery life has gone down more than it should is hard to say since it depends on how you use the phone
09-11-2019 02:02 AM
GuilhemI could be one app. The more apps you install, the more likely it is that you install one that use a lot of power. It might not use all this extra battery by it self but it can keep other apps or functions in the OS active. Usage that might not be visible in the battery usage overview. There are so many things that can cause battery drain.Are you saying that this is normal that the battery life goes from 48 hours to 24 hours just because he installed many apps? That would be really weird.
