11-27-2019 10:07 PM
11-28-2019 12:09 AM
Guri27Google camera works fine in 5z A 10 with both main sensor and aux wide angle sensor support, No complaints there. Ofcourse port from pie build wont run on A10one thing i noticed after upgrading to android 10 is accent colors function is not working. is keeps on showing the default color that is blue even after changing it. attaching the screenshot for reference. check the accent color in notification pannel and below the notification pannel its selected is cinnamon. Please Fix It. And make Google camera compatible to android 10 in Asus zenfone 5z
After Android 10 Asus 5z
11-28-2019 09:16 AM
aamod.v8Link for google cam which works completely fine, can you provide the link @aamod.v8https://zentalk.asus.com/en/discussion/13563/after-android-10-asus-5z
11-28-2019 09:10 PM
Guri27Urnyx05 latest gcam 7.2 works well for both main and aux lens. FOr accurate colours and more details Uni cam ports by @dpstar7582 works flawlessly . try bothhttps://zentalk.asus.com/en/discussion/comment/30826#Comment_30826
11-29-2019 01:29 AM
