TUF Capture Box-4KPRO smartphone capture issue
Gen2Penguin
Hi again,  Asus Help Center.
I bought the TUF Capture Box 4KPRO.
The Box is really wonderful and above all is cross platform ,but it
can't capture my smartphone output,
it just output the big word "HDCP" in white with
a black background.
I know it's related to content protection,
but I don't know which side cause the problem,
the smartphone or the capture box?
My old capture card can capture the smartphone output with the same cable
with no problem.
I don't know much about HDCP,
so, which device cause the problem?
Aureliannn_ASUS
Hi @Gen2Penguin ,
according to your inquiry, please be reminded that the TUF Capture Box 4KPRO product does not support viewing, recording, or streaming content protected by HDCP technology.
For detailed connection methods for the product, you can refer to the diagram below or the user manual link provided.
TUF_GAMING_CAPTURE_BOX-CU4K30_QSG_WEB.pdf (asus.com)
I've found the  video console app can disable HDCP,
thanks Asus!😀😀😀
