Bluetooth battery icon
ZT-f092f57aZT-f092f57a Level 1
edited September 2020 in ZenFone 6
Hi, i do not see Bluetooth battery icon in status bar. Though same bluetooth shows up with battery icon in OnePlus 6T. Can somone advise how to enable bluetooth battery icon in status bar ?
Comments
  • Settings > display > status bar icon manager
  • That does not have bluetooth battery option...
  • Hi @[email protected].com
    The bluetooth battery status will show on the quick setting menu under the bluetooth icon. Please check. Thank you.
  • That's fine... But icon is more intuitive in status bar.. i can see in OnePlus 6T
  • just connect it with you oneplus 6t, issue will be resolved :D
  • Anders_ASUSAnders_ASUS Level 6
    edited August 2019
    But then it is going to crowd the status bar and someone else is going to ask if we can only have it in the quick menu. To be honest, most headphones have much better battery life than a phone. There is no need to closely monitor the headphones battery life in the same way as the phones battery life. We wish we could make everybody happy but I'm not sure this is something that everybody wants.
