Laptop built in ai noise cancelling not working in many ways. NEED HELP
chezburger
Model Name: G513QM
Firmware Version: I think it’s G513QM.320
Rooted or not: if I’m correct rooted means I have limited access to my laptops? Yes I have limited control controls
Frequency of Occurrence: Always
😠 😡 😭 Asus I have a problem. So I realize that my ai noise cancelling is not working. 👿 I figured out it’s because my windows account is standard not administrator. So a gave all of the armory crate UAC access and the and the audio tab works. But I don’t have everything like the you power modes. But for now it’s temporarily fixed This could also be the problem. My laptop is the Asus rog strix G135QM. 💻 In the website it says it automatically detects my microphone and headphones I was using and it did but whenever I use it the ai noise cancelling only works with my built in microphone instead of my headset’s. It’s there a way to fix is? Also the noise cancelling output only gets a signal from my laptop speakers not my headphones! 🎧 😡 😡 😡 HELP PLEASE!!!
Roystoys
Zen Master III
chezburger
  1. Model Name: G513QM
  2. Firmware Version: I think it’s G513QM.320
  3. Rooted or not: if I’m correct rooted means I have limited access to my laptops? Yes I have limited control controls
  4. Frequency of Occurrence: Always
Your in the wrong forum . This forum is for the zenfone 9
Mansi_ASUS
Closing the thread since it's not related to the Zenfone 9.
ASUS_Bot
Rising Star II
