Battery issue
Abhishek CrmAbhishek Crm Level 1
edited August 2021 in ROG Phone 5
  1. Model Name:ROG Phone 5
  2. Firmware Version:
  3. Rooted or not:Not rooted
  4. Frequency of Occurrence:Most off the time
My phone shuts down when ever the battery reaches 20% and when I fully charge it it only shows 99% even if I charge it an hour extra and I have already used the phone now for about an hour and it is still showing 99% pls fix this issue
Comments
  • Have your phone upgraded to the latest version. Format the phone and check if everything is fine. If not recert back
  • Hi Abhishek Crm,
    Make sure you are on the latest software version which is .49 if not, you can check by
    Go to setting => System => About => Software information.
    1. Charge the battery to 100% & use as per your normal usage pattern
    3. settings => Battery => Check the screen & share the same
    Factory reset once
  • Neel007Neel007 Level 2
    My device is also stuck in 99% after 30 min charge 99% is showing when u disconnect the charger then 100% battery is showing same issue is occured every time . After format this issue is not solve.
  • Hi all,
    My Rog Phone 5 is with the latest software update.
    It shut down automatically at around 17%. This happened twice already. I try to charge my phone to 100% but after this happen, it is stuck in 99% after 1hr of charging.
    Now I use yhe phone(playing games) for around 30 mins and it is still showing 99% and not going down.
    Any idea for all these problems? Any solution? Or need to wait a new update?
  • VassVass Level 1
    I have the same issue mine gets shut down at 25% i have also tried factory reset nothing worked it doesn't even charge to 100 always stuck at 99
    i cant find any solution.
