AX6600 XT8 - Unable to register - web site says "Serial number incorrect" - port forwarding problem
in Others
- System: AX6600 XT8
- Battery or AC: AC
- Model: XT8
- Frequency of occurrence: constant
- Reset OS: Yes - reset to factory settings. Same problem
- Screenshot or video:
Detailed description:I cannot open port 1194 or any other port EXCEPT 8081. I have successfully opened port 8081 and can see it on canyouseeme.com, but no other port definitions are working. Also, I can't register on your web site - I'm told Serial number incorrect
AX6600 XT8 SN L3IAHZ000993 / L3IAHZ000994
Comments
Hello John,
For register issue, there should be a main SN on the box that represent the whole set.
Please register with that SN instead of individual router.
