ZenFone Max Pro M1 Android 9 Navigation Problem
Hey team this option is crash in max pro m1 3gb ram model.when I'm doing multitasking with different apps like messanger app, Facebook app, YouTube, instagram.😥😥
Best Answer
Comments
Please fix this issue in next pie update because when I'm doing multitasking with 2 buttom navigation gesture so, this feature is not run smoothly and it also hang when I'm using fast multitasking means switch apps quickly from one app over another's.
example apps which I'm using Facebook, messanger,chrome, YouTube,call app, etc...
please fixed because I'm facing this issue not only on 087 version while I'm facing with 060,063,082,084 all versions.
please take seriously my issue sir/mam.
I'm also do all trouble shooting.
Hi Singh
Thank you for your asking. Can you provide me a video for further checking? Because I just checked on my device in Android 9 V87, I am difficult to identify the issue.
which ram device you use 6 gb I'm rights
if you use 6gb ram so you not face too much ram Management issue but if u have 3ram model so you face it
see this video clip... please
Your message to asus "get lost in india" cracked me up ngl
Hi Singh
Thank you for your reply. Kindly check the testing video below with 3GB RAM device.
https://www.asuswebstorage.com/navigate/a/#/s/4033D07F8B2545118AFC289D5AAAC86B4
I will check again, yet please check if your device reacts the same in Safe Mode or after Factory Reset.
Check again the faster version as above.
May I know what kind of troubleshooting did you do before? Have you try to perform the Factory Reset?
I'm doing factory reset, software downgrade also performed safe mode but in safe mode my device is crash when I'm using two navigation gesture button, and I'm also downgrade my device at 060,063,082,084 all versions but still my problem was same because your rubbish development team always give bugs 😭
See this video I'm again show my problem which I'm facing
How you optimised this type of rubbish software please fix this problem...😭😭
please see and reply my question
ok please let me know, when we get Android 10 Full stable update at ours devices...
and one thing is why your development team not provide security patch update at max pro m1..
2 button navigation bar has always been that way from Google itself. Even on pixel devices. It was a half step towards gesture nav. If you are on pie then use 3 button.
Also Facebook, Messenger consume most RAM among all the apps.
My 3gb variant can multitask between 5 apps including chrome itself.
Use 3 button Nav !
Neither has google improved the 2 button nor will asus, since gesture nav has been done correctly.
Fast multitasking is better on 3button nav on pie and gesture on a10.
Even though i have 40 apps installed , none of them use RAM or run in background continuously. These are the basic apps that use RAM continuously and Google app if you have it enabled. 1.3GB RAM is always free if only these consume RAM in background continuously. Rest are cached.
The only third party app that runs in background is Netspeed indicator which is supposed to do so and RAM has 1.4GB Free.
