Display become unresponsive during double tap to turnoff while on a call
xbms
Model Name: ZENFONE 5Z ZS621KL
Firmware Version:WW-100.10.107.99
Rooted or not: NO
Frequency of Occurrence: ALWAYS
HI... Iam using zenfone 5z ZS621KL [Indian version ] for almost two years. It was running fine until the latest update  WW-100.10.107.99. Whenever I call someone if I have used the proximity sensor for once and then turn of the display by DOUBLE TAPPING during the call, My phone's display will not turn off, instead it goes to the lockscreen and then the whole display become unresponsive. If I use power button instead of double tap to turn off the display this issue will not occur.
For information
- I didn't dropped my phone since I bought it.
- My phone's display is working fine but goes crazy only during above said scenario.
- My phone's proximity sensor is working fine as it should be.
-I have done hardware reset thrice for this issue.
I have added a video footage of this issue along with this post. From my point of view its a software bug. All others who are reading this post and have zenfone 5z on current version of update, Please check and give your response and if anyone is having a solution for this issue will be much helpful.
1 ACCEPTED SOLUTION
Accepted Solutions
Christine_ASUS
Community Legend II
Christine_ASUS
Hi friends
I just tried again about the function in V92 and V99. Both versions have the same reaction, does the behavior appear right after any system/apps' download or update?
(1) Block the Light Sensor>back to home>double tap to turn off the screen>the device can not swipe up to unlock, click power bottom will active *swipe up to unlock
(2) Block the Light Sensor>back to home>double tap to turn off the screen>swipe down>Settings>unlock>Settings panel stuck.
Does aforementioned passage correctly describe the situation?
Hi friends
These 2 "blocking Light Sensor + double tap to turn off" behaviors are solved on latest firmware version WW-100.10.107.123.
Starting from today, this firmware will be rolled out to different region one by one randomly. Please stay tuned with our website and your consideration will be very much appreciated.
Thank you for your continued support and patronage. Cheers.
34 REPLIES 34
archilsoni412
I have tried the same thing as done by you in the video and i have the same problem.
Firstly the thing is as soon as you press the home button while the call is active the proxy sensor doesn't turn off, it still remains active and that's okay.
Secondly when you double tap on the screen, the screen should go off(blank) but It still remains active. That's one problem
And the third thing is as your screen is gone off due to double tap then proxy sensor should go off too but it isn't. So may be that's the thing which makes this problem.
These are things as per my understanding and hence is a software problem definately.
@amitgarde3 @Christine you should look at this problem too
1947msr
Rising Star I
I am also experiencing same problem, it is definitely a software bug
AmitGarde
Community Legend II
xbms
  1. Model Name: ZENFONE 5Z ZS621KL
  2. Firmware Version:WW-100.10.107.99
  3. Rooted or not: NO
  4. Frequency of Occurrence: ALWAYS
For information
https://us.v-cdn.net/6031231/uploads/TPV3067BXZ7K/video.mp4
xbms
For information
Yes i have noticed this too and i belive its a software bug i will raise this topic to mod lets await for his reply i will update you as soon as i get any info on this or else mod will comment here dont worry
thanks for video and clear explaination of problem @Anders_ASUS @STARRAIN_ASUS @Christine_ASUS @CH_ASUS @Falcon_ASUS
Christine_ASUS
Community Legend II
Hi friends
I just tested my device V99 and I didn't encounter the same situation. Can you provide me the screenshot of your Touch Gesture settings? Settings>Advanced>Gestures>Touch Gesture
V99 https://www.asuswebstorage.com/navigate/a/#/s/FC272806760649DFA1E331016F7B87274
