Battery management
After update to .70 I show battery management is too bad ... Is there any solution ? Used youtube only 43 min and take 42 % battery seriously ... Everything in that image
Comments
I have something just like it
You are a legend playing sky for 11 hrs.😀😀😀😀I get bored after 15mins.
😂😂 Yeah did you check sky take 114 % battery howz this possible
Thanks for reporting. Will look into it.
Were you juicing up while playing in those 11 hrs?
