My mobile won't recharge after battery replacement.
- Model Name: Asus Zenfonmax Pro M1
- Firmware Version: Not Sure but July update not installed, Andoid 9 only
- Rooted or not: Not Rooted
- Frequency of Occurrence: first time
I just replaced my battery and was trying to charge it but my mobile is not starting and the screen is flickering, i have tried every charger i could find but the problem isn't going away what should i do?
screen stays this way for 4-5 sec then it goes blank and then it start showing this again like a loop
Comments
Go to the service center slove her problem
My Asus max m2 also having same problem when my phone is 0% and automatically shutdown it does not take charge as you shown in picture it shows exactly same . I just pluged the charger and took the phone and chargers end again and again in phone for 10 min continuously the at after some time it is showning that it is being charged . Then the charging symbol shows
Saved money for buying Samsung Mobile
Hi, we suggest you to please visit the nearest ASUS service center for better assistance. Locate here : https://www.asus.com/in/support/Service-Center/India
