Asus zenfone max pro m1 microphone issue
- Model Name: ZENFONE MAX PRO M1
- Firmware Version:
- Rooted or not:not
- Frequency of Occurrence: regular
- APP Name & APP Version (If your issue relates to the app):
Im facing calling issues after the last update. The front person can only hear when I speak near the speaker. Please help
1
Comments
Hi, if you are on Android 10 Beta version, you can downgrade to Android 9 and see if the problem gets resolved or wait for further update.
You may also follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue
factory reset your phone after taking a full backup : https://www.asus.com/support/FAQ/1006346/
4. Last option would be to visit the service center to have
a check. Locate here: https://www.asus.com/in/support/Service-Center/India
If you got any of the solutions plzs let me know coz i m suffering from the same problem
there is not solution of this issue. I have this issue since I bought this phone 2 yrs ago. Now i have habit of speaking close to mic..
When I do the hardware test it works properly for few days and then again the problem starts
Now the receiver can only hear when I put the phone on speaker
Ugyan ez a probléma az én készülékemmel is. Nem hallanak rendesen a másik félnél. Ha lefuttatom a hardvare tesztet, akkor hallanak, de a másik félnél visszhangzik.
Miért nem tudják megoldani a problémát? Ha el tudják rontani a frissítéssel, akkor gondolom helyre is lehet hozni. Borzasztóan bosszant. Meg fogok szabadulni a telefontól, soha többé Asus!
I am
also facing the same problem
