Sound decrease ringtone volume low in beta android 10
Sound quality too cheap,low volume problem,camera not work properly, sometimes hang or leg the device.
Comments
  • Hi rj.hl.12222,
    Sound quality too cheap: For the sound quality problem, could you tell us does this appear on wired earphone/bluetooth headphones/phone's speaker? What app/app version are you using? Do you have a music link you can provide as an example? Could you describe in more details about the sound quality problem?
    low volume problem: Does this appear on wired earphone/bluetooth headphones/phone's speaker? Does it appear on system notification/ringtone/media? If media, what app/app version are you using? Do you have a music link you can provide as an example? What's the volume level that you feel too low? Was it lower compared to Android Pie or which version?
    camera not work properly: the camera quality has been improved in WW-17.2017.2004.424. Please try clearing cache & storage of your camera and check again.Β
    If behavior still appears, please tell us your camera version and show us an original photo of this problem.Β
    Please also provide us the information as below:
    Rear/front camera, the ambient brightness, which camera mode, what camera settings( Screenshot the preview before you take the picture. Also, access the camera settings by tapping the upper right three dots and screenshot this page.)
    sometimes hang or leg the device:
    Does it appear when using any apps or system functions?
    Please tell us the detailed steps you performed/ screenshot or short video.
    Thank you πŸ™‚
  • There is a sound problem in phone whether you are using headphones or without headphone.
    Youtube videos have lower sound ,ringtone sound is worse i cant even here it while in other room.
    Please improve sound quality like in android 9 or better than that.
    And yeah..PUBG didn't support HD frame rate in android 10 update.. I'm a gamer and i want that feature.
  • Sound quality is really worse on wired earphones and also on the Bluetooth headset and.
    Alarm volume is very very low..
    Ringtone is also not loud and clear
    Primary speaker is also not working properly.
  • Hi Prathamesh PS09,
    Is your phone ZB601KL or ZB630KL?Β
    Please provide your firmware version: Settings > About phone > Build number.
    Sound quality is really worse on wired earphones and also on the Bluetooth headset and: Does it appear on system notification/ringtone/alarm/media? If media, what app/app version are you using? Do you have a music link you can provide as an example?
    Alarm volume is very very low & Ringtone is also not loud and clear: Β What's the volume level that you feel too low? Was it lower compared to Android Pie or which version?
    Primary speaker is also not working properly: By not working properly do you mean on terms of quality or volume? What is the sound source?
    Thank you πŸ™‚
  • call volume and earpiece volume too low after android 10 beta version update
  • Hi Ds.SUNDAR,
    Could you tell us whether your phone is ZB601KL or ZB630KL?
    Could you let us know your firmware version? Settings > About phone > Build number.
  • Device ZB630KL
    Firmware 424.. android 10
    Sound output is very low
  • If you want to slove your problem so you can download your device in Android 9 stable it is a permanent solution Android 9 sound quality is better than Android 10
  • The Android 10 beta version is unofficial so I recommend using the official release so you don't have the same error.
