i have zenfone 4 max for 2 years with no problem,befor it i have other zenfone work great but now i see those 2 new beauty but i want to choose one,thanks alot
No i don't have Max Pro M1 I have 5z. But my friend has it and i have used it. But comparing Zenfone 5 lite and max pro M1, Max pro m1 is the clear winner coz of 5000mah battery and SD636 which is better then the processor in zenfone 5 lite. Zenfone 5 lite only good for looks and design, rest Max Pro M1
Comments
Hey
Hey bro pls don't buy asus smartphone they are very buggy truly speaking I am faid up from my 5z u should go for redmi note 8 pro or note 8
Max Pro M1 definitely
thanks alot for answering,do u have maxpro M1?can u tell me a good advice or exp in detail from it please
thanks alot for answering i go for it ?
Asus produces great smartphones. Don`t doubt! And what is your final choice? Maybe you will unboxing?
i love zenfone maxpro m2 but still cant find it in my country iran i go with beauty zenfone 5 lite
فکر میکنم اینجا بتونن راهنماییت کنن. قبلا که یکی از نماینده های ویستا بودن . الانو نمیدونم. یه سری به سایتشون بزن بپرس.
فروشگاه تی تی رستا
