Misalignment & Wrong Placement Of Status Bar Icons In Asus Max M2 ( Post By :- Arnab Chakraborty )
Luvgya
Rising Star I
Using Asus Zenfone Max M2, running Android 9, please fix the icon positions (clock, wifi etc.) at the status bar, Max Pro M1 & Max Pro M2 has the clock at the left side of the status bar but Max M2 has it at the opposite side, it looks abnormal for the Max M2. Please fix this. Attached referral images for you.
On Behalf Of :- Arnab Chakraborty
victor010
Zen Master III
Hi, we'd request you follow the below steps:
1. Clear system cache.
2. Try the same under safe mode:
Hold the power button for 5 seconds => When the screen flashes with option => Press & hold power option => You will get an option to restart in safe mode
3. If still you face the issue factory reset your phone after taking a full backup.
Hi there, you may click on the following link to download the latest update manually, request you to read the instructions before upgrading and take a full backup of the device before. Click here: https://www.asus.com/in/Phone/Zenfone-Max-M2-ZB632KL/HelpDesk_BIOS/
