Can't be open recovery mode after update on 10
sahin
I updated my max m2 on android 10..i want to back on android 9!but my recovery mode does not open! It shows "no command"!!plz solve my problem!
9 REPLIES 9
praveenrawat249
Luvgya
https://zentalk.asus.com/en/discussion/27179/cant-be-open-recovery-mode-after-update-on-10
Brother when it is showing no command then press volume up button and power button at the same time . Then You Will See The Recovery Mode
Done but not working
Luvgya
Rising Star I
praveenrawat2499
https://zentalk.asus.com/en/discussion/comment/75175#Comment_75175
Don't Press And Hold At That Time When Its Showing No Command . Just Press The Both Volume Up & Power Button At The Same Time . Then It Will Go To Recovery Mode
praveenrawat249
Luvgya
https://zentalk.asus.com/en/discussion/comment/75389#Comment_75389
Only Showing ,
CSC FASTBOOT
longpress power key to shut down
Nothing else , recovery mode is not opening 🤷🏻‍:male_sign:
Luvgya
Rising Star I
praveenrawat2499
https://zentalk.asus.com/en/discussion/comment/75467#Comment_75467
Only Showing ,
CSC FASTBOOT
First of all u need to turn off mobile
Then press and hold the power key and volume down key
When asus logo appears then only leave the power just remain ur finger on volume down key untill you see a " no command " with android image comes to screen .
After it is showing no command
Then u have to press volume up button and power button at the same time
But do not long press them just press and release
Then your recovery mode will be opened
praveenrawat249
Luvgya
https://zentalk.asus.com/en/discussion/comment/75557#Comment_75557
Luvgya
Bhai nahi hora
