ZFMP1 extreme level of lag :-/
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-16-2021 07:56 AM
I tried -
Turning off all the gestures
Clearing the internal ( 40GB left out of 64GB )
Uninstalling useless apps
Used SD Maid Pro
Turning off animations
Factory reset helps but again it starts to lag in about 2-3 months
Build - .087 (Android 9)
Pls help
Edit - I have posted this by mistake on the A10 discussion, I am sorry 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2021 04:08 AM
MayukhBackup ur dat to cloud and upgrade to a10beta latest. Mine works smoothly. Even Call of duty.Hey... I am using the MP1 (4GB, 64GB) with 128GB SD Card and facing lag like every second even while doing simple tasks like Instagram, Whatsapp, Clicking photos, scrolling through the settings etc etc.
I tried -
Used SD Maid Pro
Pls help
ZFMP1 extreme level of lag 😕
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2021 06:22 AM
qromodynmcAlright I will try that, thanks for the advice!!!https://zentalk.asus.com/en/discussion/comment/147695#Comment_147695
You should try using phone without sd card first, check if it's still laggy.
Then check phone under safe mode.
Also I don't recommend installing apps on sd card if you have any.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-17-2021 06:24 AM
RadeonPSThis is my one and only primary device so I didn't try the A10 Beta. Incase something happens I will be in trouble!https://zentalk.asus.com/en/discussion/43497/zfmp1-extreme-level-of-lag
Still waiting for the stable 😞
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2021 03:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
01-18-2021 04:47 AM
qromodynmcI completely agree with your point. 😕Funny you say that, if your company was competent enough, people wouldn't be asking for updates. Android 10 was released in q4 2019, it's been 1 year and half yet Asus couldn't release a proper update.
