12-11-2020
07:34 PM
- last edited on
01-16-2024
04:20 PM
by
ZenBot
Solved! Go to Solution.
12-15-2020 09:52 PM
Singh2 button navigation bar has always been that way from Google itself. Even on pixel devices. It was a half step towards gesture nav. If you are on pie then use 3 button.https://us.v-cdn.net/6031231/uploads/T7NBDWYR9LCW/20201215-160113.mp4
see this video clip... please
12-15-2020 09:58 PM
SinghFast multitasking is better on 3button nav on pie and gesture on a10.Please fix this issue in next pie update because when I'm doing multitasking with 2 buttom navigation gesture so, this feature is not run smoothly and it also hang when I'm using fast multitasking means switch apps quickly from one app over another's.
example apps which I'm using Facebook, messanger,chrome, YouTube,call app, etc...
please fixed because I'm facing this issue not only on 087 version while I'm facing with 060,063,082,084 all versions.
please take seriously my issue sir/mam.
I'm also do all trouble shooting.
12-15-2020 10:02 PM
