Zenfone 4 Max Pro 8.1 can use Twin Apps without problem
marcus_ck_lee
ZF Model: ZE554KL
RAM: 3G
Firmware/APP Version: WW_ZC554KL_15.2016.1907.519_20190724
Frequency of Occurrence: Always work
Rooted: No
APP Name: Twin Apps
Screenshot: https://us.v-cdn.net/6031231/uploads/ww_attachments/201909/19/185056cw0m1rma4dpn9990.jpg
Hi, I would like to share that my Zenfone 4 Max Pro X00ID ZC554KL can use Twin Apps for Whatsapp ( and other supported apps ) without any problem, including access the Contacts of my Zenfone. I have read many other people posted difficulty in doing so from different regions of the ASUS forum, some of them are: https://www.asus.com/zentalk/thread-225680-1-1.html https://www.asus.com/zentalk/thread-189572-1-1.html https://www.asus.com/zentalk/thread-219113-1-1.html I am not able to reply any of these posts because they are more than 30 days old. When setting up Twin Apps for the 1st time, you should get a prompt asking you to login to your Google account. On my Zenfone 4, I have all my contacts saved in Google. I do not have any local contacts. I am not sure if this makes any difference.
0 REPLIES 0
