07-23-2020 12:47 AM
07-23-2020 08:49 PM
07-29-2020 06:59 PM
Christine_ASUSWhen i update android 8 to 9, then i faced that problem. My sd card is fully ok other phone optimised smothly. This phone not detected any sd card.Hi tusarislam9
Thank you for your asking. Kindly provide the information below so that we can better assist you.
1. Does the issue appear after any system/apps' download or update?
2. Please try another microSD Card, does all the microSD Card could not work?
3. Does the microSD Card work in other device?
4. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
If you have any further queries, please do not hesitate to contact me.
07-29-2020 10:35 PM
