Ring tone/WW-17.2017.2006.429
jahir1378myn
Ringtone not working. Android setting media process not responding most of the time my fon is not ringing
9 REPLIES 9
Christine_ASUS
Community Legend II
Hi jahir1378myn
I am glad to hear that your primary issue was fixed. For the drain issue, to be honest, the simplest and easiest way is performing the Factory Reset, lol. Yet, you still can try some troubleshooting as below:
1. Enter "Safe Mode" and leave a 80%-100% phone in sleep(idle) mode in a night.
If the battery works well in "Safe Mode", please check on any disturbance from the installed 3rd party Apps.
2. Try to turn off the "Fingerprint"
Settings>Security>Fingerprint
3. Update your apps to the latest version, avoiding the conflict between the firmware and the apps
4. Is there any zone heating up while using/idling? What do you mean update July security patch? Since the V429 is released in July, do you mean this firmware version?
jahir1378myn
Yes after ubdate also I did factory reset then only this heatting up and drain bettery issuse start.anyway I'll follow your methods and try.
Christine_ASUS
Community Legend II
Hi jahir1378myn
Thank you for your reply. If the situation remains the same after following the methods above, please contact ASUS repair center in the country of your residence: https://www.asus.com/support/Service-Center-All-Countries/
If it is impossible to access the service center during Covid-19 period, please try Call us: https://www.asus.com/support/CallUs
jahir1378myn
Hi Christine every moments with asus getting frustrating really.difficult to get fota ubtate,have go through verious methods to do it.then getting new bugs.factoty reset again to salve them.after the ubdates phone heating up and battery drain very fast.now ask to go to service center.its annoying frutrating really.immediate after update problem started then how it can be called phones faulte I don't understant.ive Been using smart phones jnever had such a experience really.,😭😭😭
jahir1378myn
Thanks asus finally I given up my device change to a different brand now.and sold my max pro m1.specially would like to thank
Christine_asus for replying to my issues all those time.
