Reverse charging pop-up
fayazbachir
Hello,
I have reverse charging issues, on my ZenFone max pro M2, it keeps appearing although the charges is at 100% . I have tried to wipe cash partition, boot normally, switch off and on. The pop up disappears only when the charge is plugged in, its like using a desktop at the end with this mobile.
Anyone has a solution ?
Thanks in advance for your response.
Regards
25 REPLIES 25
hanhanyugs
GUYS SORRY TO PUT ALL OF THE CAPS LOCK HERE, BUT I FOUND AN EASY WAY. USE OTG USB, CONNECT IT BETWEEN FLASHDISK AND YOUR PHONE, BOOM.
I'M CURRENTLY DOING IT AND THE REVERSE CHARGING NOTIFICATION HAS GONE.
