PlayProtect is disabled by default in AOSP developer beta updates
pabixyz
Back in .407 and in .424 beta updates, play protect certification is disabled by default. So it is not passed by safetynet, I think. Thus any online transactions may not be secure. My google pay is also not working after installing the beta updates. But worked fine in .63 pie.
Speaker sound gets low, after using the phone for a while. After cleaning app datas manually and after going to recovery mode, after performing wipe cache partition again and again only solves the problem.
I want a stable update with the fixes soon.
From an Asus Zenfone Max Pro M1 user
7 REPLIES 7
pabixyz
nidhin3
https://zentalk.asus.com/en/discussion/28316/playprotect-is-disabled-by-default-in-aosp-developer-be...
Go to Settings>Security>Google play system update. After you update that to the latest version do a restart or clear cache partition.
Im on the latest 024 version and my Google play certification is enabled
I am on latest may security update from google play. But my phone's security update is from April, as per security patches given by Asus. Still every time I do a reset, it always says device is not certified. When I try to log in to my Asus id with my google id, it logs in, bit says registration failed, as this device is already registered.
Y_ASUS
Zen Master I
Hi pabixyz,
Please try clearing cache & storage of Google Play Store & Google Play Services, and reinstall Google Pay. (Settings > Apps & notifications > See all apps > Find "Google Play Store & Google Play Services > Storage > Clear cache & storage).
 If the problem still appears, please provide Google play not certified screenshot (Google Play Store > Settings) , error screenshot of Google Pay, app versions of Google Play Store & Google Pay. Also, I've sent you a PM. Please check your inbox.
For speaker sound low:
Please tell us system notifications/ringtone/ or media. If media, please tell us the app name/app version/ play store link/ music link/ volume level screenshot.
Thank you 🙂
Y_ASUS
Zen Master I
Hi pabixyz,
An updated Android 10 version WW-17.2017.2006.429 has been released.
We have improved sound volume and quality in this version.
You may manually download from our website: https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
Thank you and have a nice weekend 🙂
