Model Name: Asus Zenfone Max Pro M1
Firmware Version: 084
Rooted or not: No
Frequency of Occurrence: Everytime
APP Name & APP Version (If your issue relates to the app): Battery Related Problem
As we know Asus Released it's latest pie based security update (084)... Most of the users are facing lot of problems in this update... Specially i facing a major problem of
1. Charging Issue
2. Battery Backup Issue
3. Software Issue
1. Charging Issue:- in this problem the "Charging Rapidly" was vanished or disabled... But the power of charging in mA was upto 1200mA... But in 082, there is no problem was there... And the real charging time is 3 hrs to 3.30 hrs
(1to 100%) but in switch off mode (0 to 100%) takes 3.30hrs to 4hrs.
2. Battery Backup Issue:- the battery was not look like 5000mAh... It finishes like 3000mAh... Poor battery backup
3. Software Issue:- the main reason is software... Due to software the new new bugs was arrived... No fixes... No tests... Simply puse the updates... Even i clear cache, done factory reset... Still results are same so we can say that it's the problem of Software... Even i gone to asus customer service... They also said... Problem is not of hardware... Its the problem of software build 084.
Moderators, Admin... Please see this post and tell to developers that this is major problem not system fault or hardware Problem
Charging Rapidly is missing and showing 2hrs even i changed my charger and also brought a new charger
Charging in good condition and battery temp. Is normal... Still charging time 2hrs but actually it takes 3 hrs.
It shows 2hrs 8 min. But actually charges 2 hrs 50 min.
From 90 to 95% the charging speed decrease upto 600mA even also battery and system was good in condition...
Build number
