Internet connectivity problem on zenfone max pro m1
Dwaipayan_Dutta
Sometimes mobile can't connect to internet though other mobile with same network has no issues with internet connection. I have to restart my zenfone max pro m1 4 to 5 times to fix this.
6 REPLIES 6
AsusYouzr
Rising Star II
Dwaipayan Dutta
You are right...i though it happens only with me....
My phone also don't connect to mobile network... After retrying on/off 8 to 10 times..it connect..
And sometimes after on/off mobile data, switch access point, on/off airplane mode... Nothing works... I have to restart phone as there is no other way.
This happening daily 4 to 5 times.. Whenever i turn on my mobile data.
FIX IT.@Christine_ASUS
victor010
Zen Master III
Hi, request you to provide us with your device's latest firmware version. You can follow the below instructions to do the same: Settings -- About -- Software Information.
Dwaipayan_Dutta
victor0_ASUS
PKQ1.WW_Phone-16.2017.2009.087-20200826
AsusYouzr
Rising Star II
victor0_ASUS
I had this on pie 087 ...so i moved to beta 438.....but the problem remains the same..
If i leave mobile data on for all day.... This won't happen much...
But if i turn on data frequently means 2 or tree time in 1 hour...this happens.
