Facing low volume from speaker after updating android 10
I am facing low volume after updating to android 10 beta on max Pro m2 .
4 REPLIES 4
veeharish2005
Zen Master I
tejendrasrajawat
Asus said low speaker issue is under investigation.
I think it will be fixed in stable android 10.
abhaykrishnan02
Zen Master I
veeharish2005
https://zentalk.asus.com/en/discussion/31162/facing-low-volume-from-speaker-after-updating-android-1...
People r mainly angry because of low receiver sound say ur company to give a small update and fix this problem first before giving A10 for max pro M2
veeharish2005
Zen Master I
abhaykrishnan02
https://zentalk.asus.com/en/discussion/comment/92543#Comment_92543
I just told you that asus is investigating the issue.
Who cares how they are solve this issue, small update or an android upgrade the only thing that matters is That will be will they fix it or not .
Because of Asus saying that they are investigating this issue, I think they will fix this issue in the android 10 stable.
victor010
Zen Master III
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
