Facebook live . Problema.
pdmonzon66
ASUS_X00TD ZB602KL
I upgraded to Android 10, through the file downloaded from the Asus website (QKQ1.WW_Phone-17.2017.2004.424-20200414). All right...But when I do the live on Facebook and then I share, the audio of the shared movie is a disaster. Low volume, distorted voice, type of robot. All of this hasn't happened before with Android 9. Help me. I write from Italy.
veeharish2005
Zen Master I
pdmonzon66
ASUS_X00TD ZB602KL
Have you degraded your phone to android 9, if yes then is the problem still exists ?.
Did you get any update for Facebook after you updated your device to android 10 ?
pdmonzon66
veeharish2005
https://zentalk.asus.com/en/discussion/31329/facebook-live-problema
No update. I tried to restore but Android 10 remains.
Y_ASUS
Zen Master I
Hi pdmonzon66 ,
Please check if the behavior is appearing in the latest Android 10 version WW-17.2017.2006.429.
You may manually update from our website: https://www.asus.com/supportonly/ZenFone%20Max%20Pro(M1)(ZB601KL)/HelpDesk_BIOS/
