Charging problem
ENTRAPAN
Model Name: Max pro M1
Firmware Version: X00TDB
Rooted or not:Not
Frequency of Occurrence:
APP Name & APP Version (If your issue relates to the app): the whole phone
Christine_ASUS
Community Legend II
Hi ENTRAPAN
Thank you for your asking. Kindly try some stay-at-home troubleshooting tips below:
1. Change a charging port and a cable
2.  Please try to clean your port with soft tools (e,g. compressed air can)
3. Please try to enter "Safe Mode". If the function works well in Safe Mode yet the issue remains out of Safe Mode, please check on any disturbance from the installed 3rd party apps.
4. Also, please try "the Factory Reset"
Settings>System>Advanced>Reset options>Erase all data(factory reset)
Please note that once the Factory Reset is completed, all data, apps, settings and personal information will be deleted.
