Bugs in build no. 424
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
05-07-2020
12:19 AM
- last edited on
01-16-2024
01:15 AM
by
ZenBot
Model Name: X00TD
Firmware Version: 424
Rooted or not: not rooted
Frequency of Occurrence: n/a
1. Speaker output is very very low.
2. Notification sounds and ringtones are very difficult to hear because of low speaker output.
3. At higher volumes the speaker cracks.
4. In the homescreen the Google search bar is permanently fixed you cannot remove it.
5. When I double tap to turn off the display the lockscreen again lights up then I have to double tap again to turn it off.
6. Sometimes the notification LED doesn't light up.
7. There is a huge gap between the navigation bar and the actual display content when I use the Android 10 gestures.
8. Charging speed have been reduced quite a bit.
9. Vibration is a little low too.
10. Audio via headphone is just absolute garbage.
11. Stock camera cannot focus properly when HDR is turned on.
12. Overheating while gaming.
13. Poor network strength and frequent network fluctuation while gaming.
14. Battery drain issue.
Model Name: X00TD
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-15-2020 05:42 AM
Hi there, thank you for highlighting the issue. We have made a note of the feedback and will share it with the relevant team.
