Bug new max pro M1 A10
bidinali779
Model Name: Asus max pro M1
Firmware Version: 424
Rooted or not: not
Frequency of Occurrence:
does not support the Netflix application and when turning on battery saving the dark mode also comes alive even though the dark mode is off and the speaker is lacking shaking battery wasteful unstable signals wasteful ram wasteful application crashes and in the settings menu appears constantly zb601kl face list list finjerprint list and email list and install wallpaper and install wallpaper and Bluetooth does not burn the same as the Bluetooth logo does not appear and uses a wired headset does not work please fix this Android 10 424 because it waited too long for almost 6 months
17 REPLIES 17
veeharish2005
Zen Master I
Akasha
https://zentalk.asus.com/en/discussion/comment/91728#Comment_91728
I see, thanks for a detailed clarification. It's really a spot on answer to this bug!
No problem,
veeharish2005
Zen Master I
bidinali779
please read the Asus, I can't stand the beta update, please fix this issue
Do a factory reset . because a lot of people in this forum said '' when they do a factory reset most of the bugs which ware experienced by them are fixed''.
And the suggestion in settings are not a bug . asop does not provide a solution for users to remove those suggestion.
veeharish2005
Zen Master I
Sorry. There was a problem with the website , whenever I try to reply or edit my comment , everything in the comment/edit box which I wrote was gone and was not posted when I hit the post comment/save button so I thought there could have been a problem so rewrote it but the problem repeated.that is why there is lot of comments in this discussion by me which are the same.
bisuind70
After upgrade security patch level 5 May 2020 having build number 16.2017.2005.082 I have facing a Major problem.
1.suddenly my Phone' s display getting black and blinking continuously,then I have to hold the Power button manually untill then the phone restart. Every day I am facing this problem once or twice per day. After factory reset I can't solve my problem,So I therefore pray & request to Asus please solve my problems, thanks.
muralikirali
After my update I found that audio was blurring very often & after 10 days around Max pro M1 lost the audio & video sound & still unable to service due to non availability of spare parts & hence I am unable to set right my deaf & dump mobile due to lockdown in Chennai.
